Hello all,
I was playing around with the advanced feeder and noticed the following:
When I import the Feeder for the first time after restarting VC (Professional 4.10), it loads correctly. However, the next time I try to insert an advanced feeder into the simulation world, I get the following trace log:
Reading model from file: C:\Users\Public\Documents\Visual Components\4.10\Models\Components\Visual Components\Feeders\Advanced Feeder.vcmx
File “Advanced Feeder::ConfigureScript”, line 2, in
File “C:\Program Files\Visual Components\Visual Components Professional 4.10\Python 2\Lib\site-packages\openpyxl_init_.py”, line 6, in
from openpyxl.workbook import Workbook
File “C:\Program Files\Visual Components\Visual Components Professional 4.10\Python 2\Lib\site-packages\openpyxl\workbook_init_.py”, line 5, in
from .workbook import Workbook
File “C:\Program Files\Visual Components\Visual Components Professional 4.10\Python 2\Lib\site-packages\openpyxl\workbook\workbook.py”, line 8, in
from openpyxl.worksheet.worksheet import Worksheet
File “C:\Program Files\Visual Components\Visual Components Professional 4.10\Python 2\Lib\site-packages\openpyxl\worksheet\worksheet.py”, line 29, in
from openpyxl.cell import Cell, MergedCell
File “C:\Program Files\Visual Components\Visual Components Professional 4.10\Python 2\Lib\site-packages\openpyxl\cell_init_.py”, line 4, in
from .cell import Cell, WriteOnlyCell, MergedCell
File “C:\Program Files\Visual Components\Visual Components Professional 4.10\Python 2\Lib\site-packages\openpyxl\cell\cell.py”, line 46, in
from openpyxl.utils.inference import (
File “C:\Program Files\Visual Components\Visual Components Professional 4.10\Python 2\Lib\site-packages\openpyxl\utils\inference.py”, line 10, in
from openpyxl.styles import numbers
File “C:\Program Files\Visual Components\Visual Components Professional 4.10\Python 2\Lib\site-packages\openpyxl\styles_init_.py”, line 5, in
from .alignment import Alignment
File “C:\Program Files\Visual Components\Visual Components Professional 4.10\Python 2\Lib\site-packages\openpyxl\styles\alignment.py”, line 6, in
from openpyxl.descriptors import Bool, MinMax, Min, Alias, NoneSet
File “C:\Program Files\Visual Components\Visual Components Professional 4.10\Python 2\Lib\site-packages\openpyxl\descriptors_init_.py”, line 5, in
from .sequence import Sequence
File “C:\Program Files\Visual Components\Visual Components Professional 4.10\Python 2\Lib\site-packages\openpyxl\descriptors\sequence.py”, line 5, in
from openpyxl.xml.functions import Element
File “C:\Program Files\Visual Components\Visual Components Professional 4.10\Python 2\Lib\site-packages\openpyxl\xml\functions.py”, line 103, in
register_namespace(DCTERMS_PREFIX, DCTERMS_NS)
File “C:\Program Files\Visual Components\Visual Components Professional 4.10\Python 2\Lib\xml\etree\ElementTree.py”, line 1025, in register_namespace
if re.match(“ns\d+$”, prefix):
AttributeError: ‘NoneType’ object has no attribute ‘match’
This problem persists, independent on whether or not I have any other objects present in my environment.
I was also able to replicate the issue on a different PC.
Is this problem known?
