Let me know if you need help customizing the style, theme and appearance of the GUI.
Attached is a tutorial on how to add and create new styles and themes for the workspace.
AddingStylesThemes.pdf (195 KB)
I am getting download error “Failed - No file”
Under Attachments, did you click AddingStylesThemes.pdf? It worked for me just now.
This tutorial on styles is a bit outdated. There is no need to use UserControl.Resources. All you need to do in order to use VC styles is to reference the following namespace in XAML
xmlns:shared=“clr-namespace:VisualComponents.UX.Shared;assembly=UX.Shared”
and use it in your control as follows:
<TextBlock Grid.Column=“0” Text="{Binding Name}" Style="{DynamicResource VCTextBlockLargerLabelStyle}" />
or
<shared:ExtendedTextBox Grid.Column=“1” Text="{Binding Value}" Style="{DynamicResource VCExtendedTextBoxStyle}" />
Please see attached “VCStyle_Demo.xml” file for an example.
Regarding the resource keys for controls, I must admit that I don’t know all of the them yet but the general naming convention is “VC[Default Control Name]Style” for example “VCButtonStyle”. Attached is a word document that has some resource key I have come across and that works.
Please note that you might get a message like this when using resource key in XAML: “The resource [resource key name] could not be resolved”. I would suggest you ignore this error cause the resource will be resolved during runtime as long as you have added reference to VisualComponents.UX.Shared to your Visual Studio project.
VCStyle_Demo.zip (764 Bytes)
VCStyleKeys.zip (10.5 KB)
Really nice Jay, let us know if you find more key words. This was a very simple way to make the add-ons look native!
Hello guys
Is it possible to make a video for this tutorial? I’m a beginner at Visual Studio side and not really familiar with the meaning of the stuff you are talking about. So that would be great if i can follow your steps visually. Otherwise i cant make anything work:D
Following along, in this case, is not enough imo. You would need to have a basic understanding of WPF, XAML, XML, and XML namespaces. When I had to learn this stuff, I referred to the following site all the time.
http://wpftutorial.net/LearnWPFin14Days.html
For creating a new theme, you can use a text editor to create a new theme. Just save one theme as a new file, edit the hex color values-- not the keys-- in that file, and make sure that new file is in the same folder as the other themes used in the VC product.
For using predefined styles, @Jay I think I shared the current list of keywords with you a month or so ago. Can you post it here? What I remember is that for buttons, you will need to add some padding of your own. That is, the style won’t add it for you.
Thanks Zesty i will check the website for sure.
BR
Hi everyone,
I’m trying to use a TabControl in my DockableScreen but I am unable to stylize it…
I posted the question here and @zesty answered here sending me to this post to help me.
I understood that I should use a XamTabControl instead of a simple TabControl, but I don’t know where to find it, nether what is the bound controls namespace in
x:Key="{x:Type controls:XamTabControl}"
Thanks for your help!
EDIT 1
Searching on Google, I found that XamTabControl is provided by Infragistics WPFTM, so I added a reference to InfragisticsWPF in my project and the following namespace in my XAML view:
xmlns:controls="http://infragistics.com/Windows"
I also added the resource tag:
<UserControl.Resources> <Style x:Key="{x:Type controls:XamTabControl}"/> </UserControl.Resources>
and my XamTabControl:
<controls:XamTabControl> <controls:TabItemEx Header="{x:Static properties:Resources.EstimateCreator}"> <!-- Tab item content --> </controls:TabItemEx> </controls:XamTabControl>
But when I debug my plugin, Visual Components keeps displaying my control as following:
Up ?
Did you look at the development guide and the styles pdf in this thread? If you have a tab control in you View/wpf user control then apply the style to that element as you would using xaml. It’s been years since I’ve done this stuff, but what I remember is you need to make sure you have the xaml namspace for visual Components style reference. Otherwise, others wpuld need to help or contact support
Thank you, but I have used a lot of DataGrid Template, I can’t find the key to DataGrid. And about MenuItem, I can’t change the font which is black and is not clear on the black background.
