Hi everyone,
I am currently experimenting with .NET plugins and have been following this tutorial from the academy:
Add a Background Plugin | Visual Components Academy
However, when I try to test the software, I encounter the following warning:
| Severity |
Code |
Description |
Project |
File |
Line |
Suppression State |
| Error |
Unable to copy file obj\Debug\UX.Example001.dll to …..........\Program Files\Visual Components\Visual Components Premium 4.8\UX.Example001.dll. Access to the path ‘…..........\Program Files\Visual Components\Visual Components Premium 4.8\UX.Example001.dll’ is denied. |
Example001 |
Does anyone know what I might be doing wrong?
Kind regards
make sure VC is closed and try run Visual Studio as Administrator.
Problem solved!
Apparently, I had to remove the dll-files from the ProLean add-on store. I’m not sure why, but it worked afterward. Thanks for taking the time to look into my problem!
Thanks for the reply!
I restarted my laptop to ensure that my VC was no longer running in the background. After running the program as an Administrator, I encountered the following exceptions:
I suspect it might be related to the DLL file of the add-on store, but I’m not entirely sure.
This is the error from the DLL file of the add-on store. (I can only attach 1 media item per post as a new user)
I recommend you to reinstall VC and clean locations of Python AddIns in between.
