Visual Components Experience.apk
Hello, everyone! I downloaded the latest version of Visual Components Experience in the Google Store and tried to use it to open the “.vcax” file exported by VC4.8, but after opening it, the scene was blank, and I could open it normally with the Visual Components Experience of the windows system. Why is that?
Hi ease,
Is the layout maybe pretty big?
In this case it might be because the camera is moved out pretty far and the layout in distance is clipped away. Zooming in a little bit should do the trick.
Alternatively, there’s a little hack: Activate “Use recorded camera” in settings while the layout is loading. Only works if you actually recorded the animation with the camera close to the layout.
Let me know if this helps.
It is ‘ABB Turntable Demo’.And the camera lens is very close.
