Hi. I am trying to modify a robot base frame within a python script.
How do I do that?
I would like to find a specific robot base frame
Load its position matrix
Modify the matrix
Save the new matrix back to the base frame properties
How do I do that?
Modify the matrix
Following python logic should work:
robotController = robotComponent.findBehaviour(“ControllerName”)
listBases = robotController .Bases #getting the list of all Bases of the robot
for base in listBases:
if base.Name == “MyBaseName”: # getting a certain base
posMat = base.PositionMatrix #getting the position
posMat.translateRel(100, 0, 0) # e.g. translate the position realatively in x-direction
base.PositionMatrix ( posMat ) # assign the new position to the base
I get the following error. Is this because I need to specify a controller name? If so how would I know what this is?
SyntaxError: invalid syntax
File “IRB 2600-20/1.65::PythonScript_2”, line 11
ok I change this to be:
robotComponent = getComponent()
robotController = robotComponent.findBehaviour(“IRC5”)
I found the controller name under the behaviours of the robot in the modelling tab.
However, now I have a new error:
File “IRB 2600-20/1.65::PythonScript_2”, line 41, in test
TypeError: ‘vcMatrix’ object is not callable
ok. I think I solved this.
base.PositionMatrix = posMat # assign the new position to the base
there should be an equal sign to assign the variable posMat to base.PositionMatrix and not brackets around it.
Those “double quotes” look a bit strange, like a ditto mark. Try to use single quotes robotController = robotComponent.findBehaviour(‘ControllerName’)
If those not work, please publish your code so we can give it a look.
Ok so it seems my replies are displayed in the wrong order after being moderated giving the impression this is still not solved. However, it is solved so I will write the solutions in order.
I got the following error. This is because you need to specify a controller name.
This was solved by:
This throw up the following error:
This was solved by:
The original
This is trying to called the method by the name of posMat rather then assigning its value to the positionMatrix.
