I am trying to add the “Layout Info” to my custom post processor so that it is available in the header of my welding program but I cannot seem to locate where this information is stored in VC.
Use vcHelpers.VcmFile module. It is documented in the python API
vcHelpers.VcmFile provides access to the metadata of a local component file.
Contents ShowHide
Constructor
Methods
Examples
Constructor
The object type for a local component file and its metadata is ComponentData.
Name
Return Type
Parameters
Description
ComponentData
vcHelpers.VcmFile.ComponentData
String filepath
Create a new ComponentData object for a given file.
Name
Type
Access
Description
Author
String
RW
Defines the author of file.
Description
String
RW
Defines a short description about file and its use.
DetailedRevision
String
RW
Defines the version and change history of file, for example Major.Minor.Batch.Revision numbering.
Email
String
RW
Defines the contact email address of file.
Icon
String
R
Gets the URI of file’s icon.
Logo
String
R
Gets the URI of file’s logo.
Manufacturer
String
RW
Defines the manufacturer of file’s real-world model.
MaxPayLoad
Integer
RW
Defines the maximum payload (in kilograms) of the component, for example a robot gripper.
Name
String
RW
Defines the name of component.
PreviewIcon
String
R
Gets the URI of the image displayed when a user previews file in the eCatalog panel.
Revision
Integer
RW
Defines the revision number of file.
Tags
List of Strings
RW
Defines a list of tokens used to describe application, industry and other information about the component.
Type
String
RW
Classifies the component by type.
Website
String
RW
Defines a web address/link to associate with component.Note: This link is included with the component in a recorded 3D PDF.
Methods
Name
Return Type
Parameters
Description
write
None
None
Saves changes made to the file.
Examples
Example. Access, edit and print component metadata
from vcHelpers.VcmFile import *
cd = ComponentData(getComponent().Uri[8:])
cd.Description = ‘A high volume feeder’
print cd
