I’m simulating pick and place process with Need and Feed works process and every time the part reaches the end of the conveyor I change its ID and then pick it and place it again on the conveyor but with a different rotation.
I’m trying to repeat that 4 times ( the part is a rectangle)
After doing it 4 times I feed it on a conveyor.
The problem is that I can’t have 4 parts transporting on the conveyor simultaneously (cause of the different Product ID).
Works with Palletizer.vcmx (1.9 MB)
Here it is…
I want to load 3 parts one after another and then every time I pick the part I want to place it again but with 90-degree rotation after the part makes full spin iI want to unload it to the outfeed pallet. (Maybe when you launch the simulation you will get the idea…)
Sorry I’m bad at explaining…
I’ll be glad if you helped
Thanks for the example… unfortunately “Component or layout file is newer than application.” is one of the errors that I get, the other one is “ERROR: No routine: NewPart found”… and nothing is happening.
Is there a work around this ?
