VC 5.1 Modeling request
Hello VC,
Having used version 4.10 for a long time, I created a layout by configuring the movement of links in the Modeling tab using Python.
EX)
servo = comp.getBehaviors(“Servo Controller”)
OnRun
servo.move(100)
servo.move(0)
Just like the setup above, but it seems like a lot has changed in 5.1.
It seems that it should be connected to the motion controller, not the servo controller.
Is it possible to configure the layout in version 5.1 using the method used in 4.10?
What I want is to define the servo controller in Python, as in version 4.10, and use commands like servo.moveJoint and move API.
Best regards,
Python 2 scripting and the servo controller behaviors are still available, but the eCat content is gradually moving to Python 3 scripts and the new motion controller.
Hello TSy,
Looking into the distant future, it would be good to know how to use Python 3 scripts and motion controllers.
The academy only provides materials for basic signal sending and receiving using py3; is there no material on how to handle joints defined in the motion controller?
For moving joints using the motion controller, see the script examples in bottom of this page: vcMotionController
As TSy said, you don’t really need to update an existing layout to use Python 3 and motion controller yet, since the servo controller and python 2 are still there.
