Statistics - set graph constant maximum Y-axis value
Right now, each graph automatically scales the Y-axis based on its own highest value. This makes them hard to compare - see this example. The lines seem equal, although max values in each are 91, 57, 100, 39 - completely different values.
Is it possible to set a constant maximum Y-axis value to 100% for all graphs so they all use the same scale and are easier to compare?
I don’t think that’s possible in VC, what I often do is export it as CSV-table and then in Excel create custom charts with the correct scale.
