If I want to record the value of each real value, the real value change its value from time to time.
and i want to display the value on statistic chart.(line)
Because now vc statistic function only record the interval time value!
Could VC achieve this function?
Can i chang the statistic interval to when the real_value changes?
jes I think so. → When you create a Statistics chart you see you can select a property of an component! → So what will happen if you write your desired value to an property and use this?
But the time point I want to record the value is when the value changes, not the interval time.
Thank you!
