I am having trouble simulating a robot routine beacuse one out of every two times the software crashes when I press “Play”. When I open the software again the following message is printed in the Output panel:
I am using the KUKA version of Visual Components but the software is essentialy the same.Traceback (most recent call last): File "conveyor::PythonScript_2", line 17, in <module> File "C:\Program Files\KUKA\KUKA Sim Pro 3.0\Python\Commands\vcHelpers\Robot2.py", line 973, in getRobot return vcRobot2(roboComp, controller, executor, graspContainer, signalMapIn, signalMapOut) File "C:\Program Files\KUKA\KUKA Sim Pro 3.0\Python\Commands\vcHelpers\Robot2.py", line 73, in __init__ self.Program = executor.Program File "C:\Program Files\KUKA\KUKA Sim Pro 3.0\Python\Commands\vcHelpers\Robot2.py", line 31, in __setattr__ if name == 'Speed': ReferenceError: Executor does not have a program associated.
The application I am trying to reproduce is very similar to the “Place parts on moving objects” lesson (http://academy.visualcomponents.com/lessons/place-parts-on-moving-objects/) so I don’t know where I might be going wrong.
Also here is the python script running on a conveyor which receives components from a feeder and these are supposed to be marked by a robot:
from vcScript import * from vcHelpers.Robot2 import * import vcMatrix robot_name = "KR 10 R1100 sixx" x_dots = 3 y_dots = 3 d_dots = 50 x_offset = x_dots%2 y_offset = y_dots%2 app = getApplication() comp = getComponent() path = comp.findBehaviour("OneWayPath") robot = getRobot(app.findComponent(robot_name)) def OnRun(): while app.Simulation.IsRunning: if path.ComponentCount > 0: part = path.Components[0] robot.ActiveTool = 'Marking_tool' mtx_dots = vcMatrix.new() mtx_dots.rotateRelZ(-90) mtx_dots.translateRel(-10) mtx_loop = vcMatrix.new() mtx_loop2 = vcMatrix.new() mtx_loop = mtx_dots for i in range(0,x_dots): mtx_loop.translateRel((i-x_offset)*d_dots,0,0) for j in range(0,y_dots): mtx_loop = mtx_dots mtx_loop.translateRel(0,(j-y_offset)*d_dots,0) robot.linearMoveToMtx_ExternalBase(part,mtx_loop) mtx_loop = mtx_dots delay(0.5) delay(5)
Thank you
simulacion_marcado.vcmx (1.01 MB)
