Hello all,
I am trying to set up a feeder process to create batches of 6 different products. I have already built the layout and flow groups for all products. I’ve also already made the “welds” for each product. I used a regular process node with a create statement to prepare each product individually up to this point but I am now trying to have them all run in one simulation. Essentially if I use a regular process node and only run one product the simulation works perfectly.
My problem is that when I try to switch the process node out for the feeder process the parts are being created at a different orientations to how they were created from the process node. So far I’ve tried editing the OriginFrame in the Product Type Editor and changing the origin of the product neither of which has worked.
Has anyone else ran into this problem? Does anyone have any ideas on what would be causing this or how to fix it?
Thanks in advance!
