The first time you use the ray sensor you detect the signal and Reset simulation ,the second time you run the simulation you don’t detect the signal and the second time you restart the software the simulation works the first time you reset the simulation and the simulation doesn’t work
Maybe it causes because i does not set Realsignal and componentsignal and just set boolsignal first time,now it was solved.
How do you make partially invisible features visible just one operation on a modeling page?
