[Resolved] Robot not entering Main program, IsEnabled automatically unchecked on simulation start
I added to my layout a robot to pick and place products. The cycle should activate every time a signal (IN 100) turns True.
However, at the moment robot is not entering the subroutine, even though the signal is turning on. It does not even seem to start the Main subprogram. Why is that?
In this case I’m not using process modelling, just signals.
Is the robot executor enabled and set to loop automatically?
Yes - actually every time I check IsEnabled and start the simulation, it gets unchecked automatically. :thinking:
Being attached to the robot transport controller does that just for safety. Having robot program do one thing and robot transport controller forcing the robot do another thing at the same time is not a desired situation.
Record/Execute routine for transport links or RunRobotRoutine statements are then safer well-managed options, as they don’t run the Main routine from simulation start.
→ Use the robot without the transport controller when programming it
