Python 3.x: 'Components' property of a Two-Way Path
Hi all,
I’m trying to become more experienced with the Python 3 API. If I understand it correctly, the vcContainer class (which the vcTwoWayMotionPath inherits from via its parent, vcMotionPath) has a ‘Components’ property to indicate all items present on the path. However, path.Properties["Components"] always returns ‘None’, indicating I likely have the wrong property. On the other side, path.Properties["ComponentCount"] does return the actual component count.
Therefore, my question is: How can I get a list of vcComponents currently on my path via the Python 3 API?
Thank you in advance,
~B.
It’s simply “path.Components”:
  • Stuff in this section of the documentation are “python properties” similarly to what is demonstrated in Python property() function - GeeksforGeeks, e.g. attributes that can be get/set/get and set depending on how they were defined
  • Stuff inside “Properties” (=the property container) are vcProperty objects that have Value attribute for getting and setting the value, and the data type must be among the supported property types of VC API.
Thanks for the clarification, that helps a lot!
