i want to set the IsReadOnly-State of the component.Name-Property to true. I successfully call it but nothing happens?!
Can someone help me with this?
Thank you & Regards
Thank you & Regards
On the current 4.1.* release, I suspect that most of the flags on IProperty actually does not work. Some flags on IComponentProperty do work (i.e IsEditableWhen… flags). For example if you want to make your property read only, you should do the following.
var prop = comp.CreateProperty(typeof(string), PropertyConstraintType.AllValuesAllowed, “my_prop”);
var compProperty = (IComponentProperty)prop;
compProperty.IsEditableWhenDisconnected = false;
Hope that helps.
Works perfect! Thx
