Hello experts!
I’m currently working on a flipping mechanism for boxes that uses an arc-shaped guide. Sounds simple enough, but I’m running into a weird issue in Visual Components 4.9.2.
The boxes just won’t get close enough to the arc surface during the simulation — they stop way earlier than they should, even though visually there’s still a gap. I’ve set the collider to Precise mode, but it feels like the engine still treats the curved geometry as some kind of jagged triangle rather than a smooth arc.
I thought it might be a mesh issue, so I exported the model as STL, then even converted it to OBJ using Blender to see if better triangulation would help. Unfortunately, nothing changed — the behavior stayed exactly the same.
Has anyone else run into this with curved surfaces in VC 4.9.2? Is there some trick to preparing the geometry so the simulation actually respects the real shape? Or is this just how VC handles STEP imports and I need to work around it somehow?
I’ve attached the STEP file I’m using. Any advice or shared experience would be hugely appreciated!
Thanks in advance
Guide.stp (10.8 KB)
