I try to generate circle path for welding application using Path Statement. When i choose curve of circle, points are generated on the path but always start point (and end point) is in the same position. I can trim start and end with shift button but i have no idea how to select where path should start.
The only solution I found was to manually change the order of points in the path after it was generated
