While trying to model and simulate the cooperative work of a manipulator assembled on top of a mobile platform, on which the mobile platform moves the manipulator to the desired picking / placing position and the manipulator grabs the parts, I am facing a problem.
The mobile platform moves to the desired position and stops were it is desired (around 12 sec.). It stays stopped at the spot while the manipulator grabs a part for transportation and after this, when the mobile platform should restart its motion, it “jumps” to forward a position along its desired trajectory (around 33 sec.).
The programming for this behavior was performed in Python.
We cannot understand what the problem with this model is, and why the mobile platform doesn’t resume its motion from the position where it stopped.
The developed model, where this can be verified is attached to this email.
It seems that the vehicle position will be offset after grasping action, when you continue moving the vehicle. This can be avoided by always clearing the previous movements before giving new moving instructions, like you did in the first phase (line 26).
vehicle.clearMove()
I would move it to the Move function.
#Add Control points p1 and p2
def Move(p1,p2):
vehicle.clearMove()
for p in [p1, p2]:
vehicle.addControlPoint§
The mobile platform moves to the desired position and stops were it is desired (around 12 sec.). It stays stopped at the spot while the manipulator grabs a part for transportation and after this, the mobile platform does not go all the way, that is cuts off path.
The programming for this behavior was performed in Python and to define its path we used vectors.
