Mapping position of human model on the floor to visual components
I was working on a project where it is needed to track the position of the human operator and the human model on the 3D world need to follow the positions accordingly. I am sending the coordinates of the human position via mqtt to VC. However I wasn’t able to make the human model follow the coordinates. At the moment the human model only moves from a fixed workstation to another fixed workstation. My question is, is it possible in visual components to not-fixed position of the human operator, whose coordinate can be sent in real-time ? if so how is it done ? thanks
You can set any simulation component to any location by setting the PositionMatrix through the API. If you track a position from some external source, you can write a script that updates the resource PositionMatrix each time a new position is received through MQTT.
