I can’t see a variable named “block”… ![]()
Hy
Im assuming the block geo is the variable, however if i change that to jsut block it brings up incorrect syntax
Nevermind I solved it…
What that error means here is that you haven’t defined the variable “block” as I also cannot see it. This explicitly means that you define it like this:
block = “something”
Here you have defined pallet = “something”
br,
Lefa
Thank you, I read it and then went back over it again appricate the help thank you
