Hello everyone
I am currently working on a simulation in Visual Components and I’m facing an issue with transferring packages within my system.
Setup:
I have an infeed conveyor and two outfeed conveyors (left/right). In between, there is a moving shuttle (linear axis) that moves left or right depending on the sorting decision. On the shuttle, there should be a conveyor that transfers the packages to the selected outfeed.
Problem:
I am not able to get the package transfer from the infeed conveyor onto my system (the shuttle) working properly.
The packages disappear at the end of the infeed conveyor because there is no valid flow defined.
I have already created two process flows, but this does not solve the issue.
In the middle, I do not have a functioning conveyor that actually transports the packages.
When I insert a VC conveyor and assign it to my shuttle, only the geometry is transferred, but not the actual conveyor functionality (no transport / no “physics”).
As a result, I cannot achieve a proper transfer between the infeed conveyor, the shuttle, and the two outfeed conveyors.
Questions:
Is there a way to operate a functional conveyor on a moving shuttle in Visual Components?
Or is this type of scenario typically handled via process logic (e.g., stopping, “capturing,” and releasing the product)? If so, what would be the recommended approach?
How can I prevent products from disappearing at the end of a conveyor when no direct flow is defined?
My main goal is a stable and visually plausible solution; a perfectly accurate physical simulation is not required.
Thank you in advance!
