How to set up Conveyor X-dive Routing Rule to identify the product attribute ID entering the product and allocate different exits?
The variable you are referring to is an integer, so you can use ‘integer table’. Then you can create your custom rules. Let me know if you run into any troubles
The RoutingRule only works with the “Component properties” of the products.
