I am currently working on a Digital Twin project. The vacuum gripper signal is correctly received in Visual Components, and all robot movements are synchronized with the real robot. On the real machine, the vacuum gripper can successfully pick up the box, but in VC the box does not attach or move with the gripper.
The vacuum signal is active, but the object is still not being picked up in the simulation.
At this point, what should I check or configure next in order to make the vacuum gripper attach and lift the box correctly inside the program?
GPsimDigitalTwin2.vcmx (1009.0 KB)
