How to make the command grey?
How to make the command grey, that is, unable to operate?
Hi!
That can be achieved via .NET API for your own custom actions/commands by assigning canExecute handler for the ActionItem.
It’s explained in the .NET webinar at 53:50
http://academy.visualcomponents.com/webinars/programming-application-plugins-with-net-framework/
EDIT: The vcCommand Enabled property (Python API) should do the trick but seems not to work
Hi!
Thank you very much. I also tried using the Enabled property of vcCommand, but it did not work.
If I have to use the .NET API, I think I should study the C# language first.
