How to control a mobile robot to pick products from a specific direction?
Hi everyone,
I’m working with Visual Components and trying to figure out how to control a robot to pick a product from a specific direction.
Here is my current setup:
The robot is directly attached to the mobile base using a Mobile Robot Transport Controller. The “pick” frame is modeled in the Flow Component, and the robot approaches the product from above.
The robot attaches to the Robot Transport Controller (RTC), which then attaches to the mobile base, utilizing the L/UL Assist of Transport Link Property assigned to the RTC. The robot still approaches the product from above.
How can I configure or control the robot so that it picks the product from a defined direction (e.g., specific approach vectors or frame orientations)?
Any advice, examples, or steps would be greatly appreciated!
Is the product an Assembly? The robot should adjust its approach position when using a pick frame, but the pick frame doesn’t work with Assemblies, as the robot is picking the whole assembly and not the product within.
If you need to pick an assembly, you could define it as a product by attaching all components to the base in which the pick frame is defined and select this base as a product. Then later replacing it by the “real” assembly.
