Hello everyone,
Description:
A device flows into the system starting from the input node, passes through one or more test sites, and finally exits at the output node according to the following rules:
- The device must be tested again if it fails a test before reaching the finish line.
- It cannot use the same test site that it has already visited.
The material flow of the system is shown below:
Question:
Let me clarify my questions before describing what I’ve tried:
- How can I block a product that has a specific property value?
- How can I manage the matched Need and Feed connections using the Python API?
- Additionally, is it possible to create a custom vcProductFilter object that allows us to accept or reject a product instance based on our own logic?
Something I’ve tried…
According to the VC Help documentation about vcProductMatcher, it says:
A match can be made if the process group ID of the Need and Feed matches, the product type is accepted by the Need (defined in vcProductFilter), and a valid transport solution exists between the transport nodes.
Based on this, I tried creating a property called Use_Site on the Device to record which test sites it has already used.
Then, I set a Product Filter in the process statement of each site.
However, I’m not sure how to write the correct expression, or even which type of filter I should be using.
It seems that the filter expression doesn’t allow syntax like "str" not in "str".
I encountered an error in the expression used in the statement’s filter. The message looks like this:
Error in . Expression '"Test Site #22" not in Product.Component.Use_Site' refers to the variable itself.
I also tried handling the Need / Feed match through the Python API.
I called match.tryCancelMatch(), but it returned None, and the match state remained in Create.
Hmm… it seems that the match can’t be canceled as I expected.
def register_match(new_):
Register a match event for need/feed and handle the match logic.
def need_feed_match(match): # type: (vcProductNeedFeedMatch) -> Any
transport_ = next(x for x in transport_items if x.need_item == new_ or x.feed_item == new_) # type: TransportItem
if not transport_:
error('No TransportItem found!')
return
#mo
print("==========================================")
if match.State == VC_MATCH_STATE_CREATED:
match_state = "Created"
elif match.State == VC_MATCH_STATE_CANCELLED:
match_state = "Cancelled"
elif match.State == VC_MATCH_STATE_FINALIZED:
match_state = "Finalized"
elif match.State == VC_MATCH_STATE_DISPOSED:
match_state = "Disposed"
print("This Match Object Type: {}".format(match_state))
print("Matched Need's "
"Target Node: {}".format(match.MatchedNeed.TargetNode.Component.Name))
print("Matched Feed's "
"Source Node: {}".format(match.MatchedFeed.SourceNode.Component.Name))
print("Matched Product Instance:\n\t"
"Product's Mark: {}\n\t"
"Product's Used Site: {}".format(match.MatchedFeed.Product.Component.Mark,
match.MatchedFeed.Product.Component.Use_Site))
if comp.Name in match.MatchedFeed.Product.Component.Use_Site and transport_.type == 'need':
print("This matched need feed should be canceled!")
print(match.tryCancelMatch())
return
else:
transport_.need_item = match.MatchedNeed
transport_.feed_item = match.MatchedFeed
transport_.match_item = match
transport_.match_time = sim.SimTime
transport_.product = match.MatchedFeed.Product
create_transport_target(transport_, match.MatchedFeed.Product, transport_.type)
if transport_.type == 'feed':
solution = transport_system.findSolution(
transport_.feed_item.SourceNode,
transport_.need_item.TargetNode,
transport_.product.ProductType.FlowGroup
transport_.product.TransportSolution = solution
transport_node.beginTransportOut(transport_.product)
match.finalizeMatch()
return need_feed_match
VC OUTPUT PANEL:
This Match Object Type: Created
Matched Need's Target Node: SLT Trolley Test Unit #22
Matched Feed's Source Node: PlatformBase
Product's Mark: R0
Product's Used Site: SLT Trolley Test Unit #22,
None
