"How can I make the box move up and down together with the vacuum head after it is grasped?"
I would really appreciate any help or guidance from the experts here. Please see the attached files for more details. Thank you so much
GPsimDigitalTwin2.vcmx (987.4 KB)
Hi @bobby_RMUTTO67,
I think this can be achieved by moving the GraspContainer under the GP-CENTER joint - that way the container that holds the grasped object is attached to the vacuum head and will move along with it. Also, I think the other GraspContainer might not be needed.
It might also make sense to add some Wait statements into the robot program to wait for the gripper parts to reach their open/close positions and then proceed with the flow.
Try this:
GPsimDigitalTwin2_Modified.vcmx (966.8 KB)
@hans I followed what you suggested, and it really worked. Thank you very much!
I am currently working on a Digital Twin project. The vacuum gripper signal is correctly received in Visual Components, and all robot movements are synchronized with the real robot. On the real machine, the vacuum gripper can successfully pick up the box, but in VC the box does not attach or move with the gripper.
Hi Bro @hans The vacuum signal is active, but the object is still not being picked up in the simulation.
At this point, what should I check or configure next in order to make the vacuum gripper attach and lift the box correctly inside the program?
@bobby_RMUTTO67 responded under the other thread
