Hi guys,
I was wondering if its possible to generate txt file on trigger using a signal
For example if I’m having a part on conveyor passing through conveyor signal, how can I generate a txt file when the signal is true.
Thanks in advance
Hi guys,
Thanks in advance
You select the Signal (Modelling Tab) and in the Field “Listeners” you add your PythonScript.
Then you need to extend the function OnSignal which is always executed if the SignalValue changes state.
from __future__ import print_function
import os
def OnSignal( signal ):
home = os.path.expanduser("~")
file = os.path.join(home, "Desktop/test.txt")
with open(file, "w") as fd:
fd.write("Hello World")
fd.write("\n")
text = str(signal.Value)
fd.write(text)
fd.write("\n")
There is one possible problem. If your HDD is in SleepMode and you get this signal, then the whole simulation should block until the OnSignal function were handled (data were written). This function does also not allow time taking movements of a servo controller.
Thanks a lot. You sir are a hero.
One last thing…is there a way I can read the product ID when it passes through the signal
Thanks
There are different types of Signals:
You need to get the ComponentSignal, where the Value is the component.
I attached an example and a video.
belt_with_productid.vcmx (776.3 KB)
2020-03-31 15-23-35.mkv (94.9 MB)
If someone else has better ideas how to solve it, please tell us.
As you can see, I never used the RangeSignal. Is it always sampled even if there is nothing on the path?
What I totally dislike is how to detect types. Is there not a better way?
Hello @deadeye
This does the same thing as you did but coding is simpler.
def OnSignal(signal):
if signal.Name == 'ComponentSignal' and signal.Value != None:
part = signal.Value
print 'ProductID: ', part.PruductID ,' Name: ' , part.Name
print 'Product material ',part.Material.Name
