Export STEP File question
Hello VC,
I’ve been a VC user for a long time.
I used to import 3D STEP files from outside to VC and export the optimized model back to STEP files by removing unnecessary parts.
I remember that even if I exported the STEP file back to the STEP file that I worked on in the past, the part tree that the model already had was maintained, but when I did the same thing recently, when I brought the optimized STEP back to VC, it was integrated into all one part.
Is there a way to solve this problem?
Hy @JohnKim,
what happens if you explode the feature?
Hi Captain,
When I use the expode function, it splits into too many parts. And what I want is that the STEP file simplified in VC is imported while maintaining a tree in the external CAD program.
Best regards,
Hello, John.
When importing the STEP file into VC, did you select Import > Select File > Component? If you selected Component, could you try again after selecting Feature instead?
Hello Hyeokcheol Kwon,
When I imported STEP, I always proceeded with Feature as an option.
By any chance, Hyukchul, even if you export the model as a STEP file from VC and bring it back, will the file tree be maintained the same as the original?
Best regards,
Yes, that is correct.
Even without using the method mentioned above, the same behavior occurs when importing through a simple drag-and-drop approach.
제가 이해한 것이 맞다면,
VC로 STEP 파일을 불러온 후 그 파일을 다시 Export하여 STEP으로 내보낸 뒤 그 파일을 다시 VC로 가져와도 정상적으로 트리가 유지된다는 말씀이신거죠?
I apologize. It seems I misunderstood what I was seeing.
I will check it again and review the issue more carefully.
