Hello everyone,
I am currently modelling an item which has the properties Length as well as Range. My requirement is that Range can only be two thirds of Width. I know how to set hardcoded constraints (just write sth. like “0.0-10.0” into the textfield) but this solution is not what I need.
I created the properties as follows:
prop_length = comp.getProperty("Length") prop_range = comp.getProperty("Range") if not prop_length: prop_length = comp.createProperty(VC_REAL, "Length", VC_PROPERTY_LIMIT) prop_length.MinValue = 0 prop_length.MaxValue = sys.maxint prop_length.Value = 45 if not prop_range: prop_range = comp.createProperty(VC_REAL, "Range", VC_PROPERTY_LIMIT) prop_range.MinValue = 0 prop_range.MaxValue = 2/3 * prop_length.Value prop_range.Value = 20
Does anyone know how to fix this issue?
Thanks in advance
