Dual Gripper Machine Tending -- Using Process Tab
Hi
I referred to the default VC layout to do my dual gripper case, but it is not working.
Could you take a look to see what settings are missing, thank you!
Dual Gripper Machine Tending V2.vcmx (979.0 KB)
The process is:
1. The robot picks a can from the Feeder using TCP 2.
2. The robot picks a can from Process #1 using TCP 3.
3. The robot rotates 180 degrees.
4. The robot places the can from TCP 2 onto Process #1.
5. The robot places the can from TCP 3 onto Process #2.
your routine is missing a lot of statements compared to the Layout template. It should look like this:
You also forgot to check “Swap at source” in the TransportLink from Process #1 to Process #2.
And in the Process #2, the TransportIn should be set with the Source on “From Previous Process”, not “From Component Container”
