I try to realise this how you recommended and define the moving part as component. → With the two-way path I make a “grab” then the movement starts, so far so good.
First problem: The component disappears when the movement on the path has finished?
Second problem: How is it possible to control the start and stop of the moving component?
Third problem: I want to drive the moving part just for a specific distance on the complex path?
Hi @captain_feature
You can look for ‘Vertical Paternoster’ in library. It works same but your path is little bit more complicated.
For starting and stopping you can use path.Enabled = True/False
For distance calculating you just need to run conveyor for a time then stop it. Then you know how long it runs and whats the speed of the part. You can calculate from those.
