Drawing View ignores Text feature rotation
I’m seeing an issue with Text feature when generating a Drawing View.
Hierarchy in Modelling:
Root
 └─ Switch
     └─ Transform
         └─ Text
The user rotates the main component in Home/ Process tab. The Text feature inherits the rotation through the hierarchy and displays correctly in the 3D view.
However, when creating a Drawing View as well as DWG export, the text is displayed horizontally (0°), as if the rotation is being ignored. The text displayed in Text feature is based on the component property, so annotations the drawing view is not an option.
Do Drawing Views ignore Text feature rotation? Is there a way to deal with this? I want to get the drawing view/ dwg exactly same as 3D view.
Any insights would be appreciated. Thanks!
I just observed that the text is getting completely vanished in the STEP export. Is this some sort of rendering issue with VC? The correct orientation in the Drawing View and .dwg export is important for my use case. To clarify this is what I mean with the ‘Text’ feature.
