I suggest to try using BaseName and ToolName instead of BaseMatrix and ToolMatrix. There’s an example snippet on this thread to read motion statement into motion target which you could try:
Thing with the matrices is that it probably doesn’t consider the fact that frame parent node might be different than the default (flange node for tool frame for example). Setting base/tool by its name should set both the parent node and position matrix correctly.
