I want to initialize some statistic tabs at the start of the simulation. I want to create them dynamically with Python scripts, because the amount of chart depend on how many machines I use. I try to create all charts on a single statistics tab, but no matter what I try, I always end up with a ‘1-Column 1-Row Regular Dashboard’ layout.
How to create a tab with for example the ‘4-Column 2-Row Regular Dashboard’ layout via a Python script?
edit: When I try to access any chart other than the one at index 0, I get the error:
NetInvoke: System.IndexOutOfRangeException: Index was outside the bounds of the array.
at VisualComponents.Revolution.NetProxyWrapper.NetInvokeInternal(Int32 type, Void* param1, Void* param2, Void* param3)
at VisualComponents.Revolution.NetProxyWrapper.NetInvokeHandler(Int32 type, Void* param1, Void* param2, Void* param3)
