I have a question. In the automation project, it is often necessary to count the movement beats of robots. In the figure below, multiple subroutines are created. Is there a way to count the beats of a single subroutine (that is, the robot’s movement time), or multiple subroutine beats at the same time?
Hi i think you can create a new variable for every subroutine to count how many times it ran. And simply you can increase it by 1 every time routine is called. In routine you can use your first command for assign Counter = Counter + 1.
I would recommend you use the Post Processor add-on found on the forum along with a virtual controller for calculating the cycle times, e.g. Kuka OfficeLite. For example, use the add-on to export the robot program to a testable format, and then use a controller to measure cycle times.
If you cannot do that… you can use API to try and calculate the motion time.
Option 1
The Robot Executor behavior of the robot should have a StatementHandler property, which you can use to the control the execution of statements. A StatementHandler is a Python Process Handler behavior. It has a script, which would allow you to calculate the time it takes to complete the routine.
Option 2
The Robot Executor in Python is vcExecutor, and it has a method for calling a routine in the robot program. So a simple test of comparing the simulation times before and after the call and completion of the routine could give you an idea.
Option 3
The Robot Controller in Python is vcRobotController, and it has a method for creating a motion interpolator and others for testing motion targets, but this is something you probably should not do in this case.
Option 4
A curve ball. I don’t remember, but I think the Print statement in a robot program does print the simulation time in the Output panel. Therefore, you could try to do option 2 via the GUI/Program Editor panel.
Notes about Options 1-4
It might not be accurate, but can serve as a rough idea/estimate. Be aware that you would have to implement a way to monitor motion statements and not other types in the routine. But if the goal is just to record the duration of a routine, you could create a script and run the routine several times to get a sample size and average time.
Thank you very much, but I think it will be a good feature to apply this function to a future version, which is combined with the request of my previous automation project, thank you again!
