I am working in Visual Components and I have a problem with copying components between two layouts.
I have two layouts open and I want to copy objects (including their position and connections) from one layout to another.
However:
- Ctrl+C / Ctrl+V does not work
- Drag & drop only moves the object inside the same layout
- Exported layout is scaled incorrectly and cannot be used properly
My goal:
I want to copy a group of components (for example conveyor + robot setup) from one layout to another without rebuilding everything manually.
Could you please explain:
- What is the correct way to copy components between layouts?
- Is there a recommended workflow for this?
I am using Visual Components version: 4.10
Thank you.
