I want to switch the visibility inside a component by handing over an integer to a python script.
out of a KUKA-Robot program. The integer is given by 16 Output-Bits.
For example I hand over 26482 to the routine and the feature 35400_26482 gets displayed.
I have already collected some snippets. But it does not work in KUKA-SIM 4.3.
You should be able to just replace your showElement method with the two I have provided. Basically it’s just iterating over the Feature Tree of your Component and whenever it finds a Geometry Feature it will set it’s visibilty based on the provided element id.
Here’s the code in text form so you can copy and paste it:
def showElement(element_id_int):
text = str(element_id_int).strip()
showElementRecursive(comp.RootFeature, text)
comp.rebuild()
def showElementRecursive(element, element_id):
for sub_element in element.Children:
if sub_element.Type == VC_GEOMETRY:
sub_element.Visible = (element_id in sub_element.Name)
else:
showElementRecursive(sub_element, element_id)
