After that the position in the visualisation is ok. And the matrix x, y and z parameters of the .NET object are equals with the setted values 100, 200 and 300). But I can`t find any property of which has the value for the “rotationAroundZ”. Also not in another unit (radians).
Could someone please help me to understand the problem?
Briefly put the rotation around Z (or X or Y) affects more than one value inside the matrix and that is why there is no single property that shows it. Rather you need to calculate the RZ from multiple values inside the matrix.
Of course in the API there could be a property called RZ, that would return the computed value for the angle. Like it is done with the Determinant property.
@Keke:I Knwo it to set the rotation is more as only to set only values. But I thought that after the operation I can read that values anywhere, because I see also the values in the KUKA.Sim UI.
