Hello
I am trying to control the behavior of the component with Python script.
Is it possible to call classes and methods defined in a Python script of another component from a Python script of one component?
Also, is it possible to reference Python objects created by one component from another component?
Thank you.
[Edited]
Sorry, I don’t know how to do that unless you are importing a module. If developer reads this thread then maybe they can comment on the scope/namespace of component scripts. Or if someone has an example then please share.
Otherwise, try this, https://docs.python.org/2/library/weakref.html
Thank you for your reply.
For example,
Robot 1 component
- PythonScript <— Definition of class & instantiation of that class (1)
Robot 2 component
- PythonScript <—Refer to the instance of (1)
As mentioned above, when referring to the instance of (1) from the Robot 2 component, how should it be described in the Python script of the Robot 2 component?
Thank you.
Hello zesty,
Thank you for your reply. I appreciate your kind reply.
I will be waiting for information on this matter.
I don’t think you can share instances between two python sandboxes in Visual Components. The script typically communicate data with other means. Maybe it is possible to serialize the class/instance and send it as a string etc. but sounds sketchy.
Could you describe your use case. What are you trying to achieve. Maybe we’ll find another solution for you.
