Blender Addon - Blenderer
Is it possible to render the scene on a remote computer/server with a better GPU and Blender installed? If possible for pictures and the frames of a movie.
How I would like to use it:
Make scene on my laptop -> Convert it to blender scene -> Send to a remote computer, which make the render.
In this way I can continue working on the scene while the scene is rendering. And the rendering will be faster because of the better hardware and cooling in the remote computer.
I think it is possible to program, but my knowledge of python is to limited to implement it myself.
@mschamp
Hi! It is possible. When you are rendering, tick the option “Open in blender” in Advanced category in Blenderer addon. Then when blender opens, set all rendering settings as you like, then in blender click File > External data > Automaticlly pack into .blend and then File > Save as. You now have .blend file with all your settings and model from VC which can be opened in another pc and rendered.
Hi all, how do you render videos? The default tab on the blender add on lets me select a component and lets me get an output picture of that component. How do I render the entire animation? I tried doing this on the animation tab but I don’t think its working for me.
Hy eme,
do the mighty Blender AddIn already work with Blender v2.81?
@ashdank94
Please check the documentation provided. It explains the animation rendering step by step.
Basically you need to set your start and end time. Chech the record option on. Run simulation until that check box is automatically cleared. And then click on the Render Animation. That’s it. Animation rendering uses the same file path as defined on the Default tab except the filetype will be video file type.
@CaptainFeature
There’s now a new version 2.0.2 available that supports Blender 2.81.
You’ll find the download link in the original post in this very same thread.
br eme
sometimes I have the some issues with the Blender Addon when the geomtry in the layout is heavy.
  • I try to export a renderd pic from the heavy layout -> Everything looks fine (needs some time to open the cmd, but time is not the problem) but the picture won't be exported. No Errormessage or something...
  • If I can't render a pic I think I can't render a video...
I would be incredibly assome to have a possibilty to handle also heavy layouts?
EDIT: After I was able to stop the Blender-cmd window at the right time :wink: I found out that I have not enough space… -> In our company the whole documents folder is synced on a NAS with less space :frowning:
So i fixed the problem by modifing the tempuri in Blenderer.py to another path! :slight_smile:
  • Maybe in future version it will be possible to edit the tempuri in the UI?
  • Also it would be great to get the errormessage if an error happens, so it would be easier to find the problem.
Thx & Regards
Hey there!
Since the 2.0.2 version VC gives me a Error message in the output, which I attached below. Any ideas to why this is happening?
Best regards
Dubsepp
EDIT: Forgot to mention that it’s happening after I click “Render”. The addon itself loads fine
when I export an Animation with the addon where I use a simple selfmade hdr-map I get the following message in the blender-console.
What means “cannot be made relativ”?
By the way has someone a source to download hdr-maps which consists out of one colour (white, grey,…). Or maybe can post some monocolour-hdr-maps here?
Thx & Regards
Hello.
Is it possible to render blinking lights in animation? Suppose we use AreaLight component. When its Visible property is True, the light is on and vice versa when comp.Visible = False. In this case, pictures in both states are rendered correctly. However when dynamically turning component’s visibility on and off during simulation, the rendered animation only shows the state at the start of simulation - the light doesn’t blink.
Thank you.
Best regards
I don’t know if this is possible to achieve directly from VC, but you can always open your scene in Blender and animate your light with keyframes.
Hi, gentlemens!
A have a little problem with this addon.
When I start a VC I see the following and the “Blender 2.0” button doesn’t work.
Do you have an idea what’s wrong?
hi is it possible to replace materials from VC to real pbr materials in Blender. ex aluminium material in VC converts to a PBR aluminium in blender from blender kit etc? or can i make a material library in blender that can be acsessed by blendereer?
If components was hided during simulation. I can still see it after the render. And creat light didn’t work too.
Does anyone else have the same problem? How to fix it?
I move the component far away instead of hide it.
Still using this plugin a lot, thanks so much for developing it!
I have a feature request though, would it be possible to have a an option in the Floor tab to set the floor to Shadow Catcher mode to have a transparant floor and background but with shadows?
When the plugin still used cycles it was easy, but with the new faster Evee mode you need to do stuff with the shader editor and I just can’t seem to get it to work (I have zero experience with Blender). https://www.youtube.com/watch?v=DQJ_SBpcUQE
Hello, I use your plugin and it is awesome ! I use the animation rendering get the blender file (awesome job about the time !) but I have no color from VC (my blender file is grey), what I have to do to get at least VC colors ?
Edit : I find the solution, I have just to clik on the right icon in Blender
I unfortunately found out that swept geometry will not export to RenderVideos! -> In Renderpictures it works well…
What’s the difference??
Would be great if this will work too.
Immediately after starting programm this message appears in the Output window:
File “file:///C:\Users…\My Commands\Blenderer_2_0_2__2019_12_12\Blenderer.py::”, line 14, in <module>
ImportError: No module named export_from_vc
What i can do with it?
@vadiktimez1
Are you sure you have that file in the Blenderer_2_0_2__2019_12_12 folder?
You could try to comment out the line 14 in the Blenderer.py file.
Change this: reload(export_from_vc)
to this: #reload(export_from_vc)
