When exporting an animation to PDF it is possible to give the PDF a title, which is filled in the title field of the PDF. However, when exporting a geometry to PDF there is no option to fill in a title, so PDFs end up with “Title” in the title field of the PDF. Is there a solution to add titles when exporting geometries to PDF?
I found a solution. When you export a geometry as Static PDF and you want a title above it, you need to fill in the title on the “Export to PDF” panel. This field is also used by the static PDF. Here you can also choose the Template you want.
