Add KUKA LBR iico 12i R1260 robot
There is no LBR iico 12i R1260 robotic arm in the VC library. Could you please update it? IiQWorks.Sim 1.2 now has this robotic arm!
I added iico series robots to VC 5.0 eCat. I had to modify kinematics from iiQWorks versions a bit as the simulation performance with original kinematics was really poor when using VC controller (iiQWorks uses RCS controller which isn’t available in VC 5.0). Now in VC those robots use similar kinematics as Fanuc CRX robots.
To update eCat in 5.0 you can click the plus icon on eCat and click Refresh. It takes some minutes for the update to complete but after that you should find iicos in the library.
