After upgrading to 4.1 from 4.0, none of the components from my library will connect to their interfaces. They work fine in 4.0, what has to be changed in them?
Wow, sounds terrible. Did you submit a support ticket? Are you using a script to manage the connection?
No, the script does not manage them. I didnt create a ticket, thought maybe this was a simple issue.
Could you share some example components here so that we can take a look what’s wrong?
It was a silly issue- The components I have are set up with only one of them having a connection edit button. In 4.0 I would click interfaces, then the component, then drag the wire over to the other (now yellow) component. In 4.1 they stay grey and wont connect. I added the connection name to the second component and then they connected right.
